From what I gather from Kevin Cashen and other metallurgists....high carbon steels (assuming the file is good high carbon steel and not case hardened or other non suitable material), should not get the vermiculite (or sand or anything slower than a still air quench) treatment. If they do get it, then they should be normalized and then subsequently thermal cycled (to take care of any possible grain growth during normalizing) after the machining is done. Any cooling that is slower than still air will place pro eutectoid carbides at the grain boundary...which gives a brittle steel. Of course, with forge type heat treat set ups, a spheroidized anneal is kinda hard. What I do is quench at 1475, then place into the oven at 1225°F for 2.5 hours....works wonders! But if you don't have that ability, I would cycle the blade in your heat treat set up a few times at around 1300°F. Get it to 1300°F, equalize, air cool to black. Repeat three or four times. This will soften the file well enough to grind on, without the vermiculite/sand slow cooling and bad carbide placement.
