- Aug 27, 2004
When I was young, back before the days of kit knives and luxury like that I simply bought old slip joints at flea markets. If I saw one I liked I'd pop it apart. Copy each piece best I could using nothing but hand files and saws and vices because we had nothing else. Brass, or carbon steel were my choices back then. So what I did was use brass since it was cheap.
The old boy suggesting liners of blades is probably thinking just liners only not picturing the lock mechanism. For just a set of liners any old thing could be made to work from old metal outlet covers of real brass or copper to store bought sheet steel in 410 stainless. The problem is you want a lock. The spring is needed so your choices are limited. Use anything like old spark plug gappers that are broken. The two exterior plates on those are usually right around 40-44 Rockwell if they are the gold old USA made ones. Find them at yard sales. Pennies really. If you take the pins out smooth you can even reuse those and they are long so no worries for length. Old sheets of aluminum would be fine liners but again the liner lock is an issue here also. .
For that matter you could use thicker brass and nest a hardened lock plate into the lock at the contact. You would need a mill to do that tho and that leaves you with brass. It work hardens. Can hold a weak spring set. Has been used for locks of a liner type in electricians knives and early liner locks. Wear would be okay but strength? Nothing tactical here for sure! Well, for a pocket gents folder I'm sure it would be fine.
