·The knife should have a fixed blade, non-folding.
·The blade should be made of good quality carbon steel. Carbon, unlike stainless steel can be used as the striker in the flint and steel method of fire lighting.
·An overall length of 8-9 inches is ideal to perform intricate woodcraft duties, yet is large enough to present a good target for batoning. Batoning will assist a 4-inch blade in cutting down small trees, and splitting wood.
·The knife should have a full tang; the metal of the knife blade should extend for the full length of the handle for strength.
·The knife’s spine should be squared off to be able to spark a FireSteel/ferrocerium rod.
·The knife needs a comfortable and easy to hold oval shaped handle, made of a water-resistant durable material, like micarta.
·The preferred grind is a wide flat bevel that runs to the edge of the blade with no significant secondary bevel, usually the edge bevels only goes 1/3 way up the side of the knife. The result is a very keen edge. This grind gives excellent control in woodcarving. If you carve wood, you will probably find that the flat bevels give you better control of the cut. The wide bevel face lies flat against the wood like a plain and slices wood into fine curls. Working with wood is a must when practicing wilderness living skills. Another advantage is ease of field sharpening. There is no special tool kit or other gadget required to get a razors edge. All that is required is to lay the bevel flat to the stone, and work the entire surface of the bevel. The wide bevel forms its own guide.
