- Nov 1, 2006
If that does not work try sending it back to KAI they are great people to deal with and I have nothing bad to say about the people that work there or their warranty service I'm just really steamed about 3 out of my 4 ZT knives I got 5 months apart from one another are not working the way they should and the second ZT0566 is the one that has me mad the most and it's not so much because it does not work the way it should it's the fact that the blade will not even try to flip open at all.
I have found with all my knives, that you can adjust the tension on the pivot screw, the best way for me is opening the knife and placing a wooden wedge ( see photo) between the frame lock and the opposite frame enough so you take any pressure off the blade. Now you can adjust the pivot so the blade will fall by itself without any side play at all.
Remove the wedge and try opening the knife again. If there is still an issue it's not likely from the pivot area. With my 0566 adjusted this way there was still to much pressure applied to opening the knife with the flipper. At that point I made an adjustment to the torsion spring. I don't recommend this unless you have the experience to do so. It now opens with lightning speed and no extreme pressure using the flipper. On mine the torsion bar was pre-loaded to much. It had still opened after adjusting the pivot but made my finger quite sore doing it a few times until the torsion bar was adjusted.
Best of luck with yours.
Ron
