Making and burning firestraws. (lots of pictures)
It must much easier to write this up by adding captions to photos, so click here for lots of picture and some information. This was my first attempt.
L
Good job. How do you melt the ends? Pinch them with the pliers and flame them?
Yes, I should have shown a better picture of that. I'll edit the captions.
I'm also going to try the cotton balls w/ PJ in alluminum foil packages to see how the burn time, and elemental resistance compares. I think I am really going to like the size of the straws though.
Ok, so I've messed with this a little more.
I did some comparison times of the cotton straw vs. a cotton ball in foil, and they seem to burn about the same when fluffed well. This is obvious now, since the new way I do the straws, I get one cotton ball per straw.
I was experimenting today with magnesium shavings added to the PJ cotton. It didn't help it start better, it may have made it actually burn a little bit faster. BUT, I did notice what seemed to be a lot better wind resistance. When I blew on them, the magnesium shavings seemed to ignite and keep the flame going. It's hard for me to get scientific, and if anything, it just adds a little bit more fun to making the straws. I made the straws a little shorter so that they would fit nicely in my altoid tin. I also used some regular blue cotton balls, which worked MUCH easier than the cotton pads. I also used a lot more PJ.
I started with a small piece of dry cotton, and ended with one as well (which I started to do in the pictures), and this made it very easy to pack.
I also made some mini-straws, that are maybe 1" to 1.5" long. And they have about 1/3 of a cotton ball. I'm quickly running out of room in my tin, so I thought I might try these instead of a full straw.
L
When you all say "soak" the cotton ball in PJ, how are you doing this? Are you heating the pj to a liquid state and then letting the cotton ball absorb it, or just rubbing the cotton ball in the jar or what? :confused:
I just work it in with my fingers. Works beyond well.
With the cotton balls I pull them apart into as many pieces as possible. Then I put them back together in a loose wad, about twice the size of the original cotton ball. Then I take two fingers and just get a pretty liberal amount of PJ and rub it in well. If you do to much, you will have obvious excess, and it might make it a little difficult to pack into the straw. I know when I have enough when it is a little difficult to fluff them by hand. In the wild, I use the top of a knife to fluff it up a little bit.
I found the right amount buy putting different amounts on 3 different cotton balls, and observing how they burn.
L
As part of the original article (which was editied out before publication) firestraws were made in a 2" length and put inside of stripped paracord. They were used in a neck knife lanyard this way, one of my hunting partners even used them as bootlaces. There are many possibilities.
JP
L
What exactly is "PJ"? I never heard of it before? Is it easily flammable substance or what? I tried googling it and couldn't seem to find much.
I`d never seen these before. What a great idea for storing a PJed cottonball without making a mess of your gear! I also liked the idea of storing a couple in a hollowed out paracord lanyard. I`ll be making a couple tonight!
I put mine in a plastic baggie with some vasoline, zip it closed, the then massage it well together. It's a little less messy that way.
