- Jun 11, 2006
well i have been making knives for a long time now but never had a nice grinder. the nicest thing i had was a hand held belt sander that was my dads, i used it so much i burnt out the motor over a 5 year time of making knives. im now 25 and live an a apartment and have been wanting to get back into it but using a good grinder. what made me think about making a grinder is that i worked part time a nordic track and the store just closed and i snaged a super hevy duty dc verabile speed motor reted a 3hp continuis duty but i can get more out of it if i push it for shorter amounts of time. its quite a beast in that its about 6" by 13". the shaft is around 5/8" i think. The first qusetion i have is this. because its dc i was hoping to run ac from the wall to a veriable switch like a dimer switch for your lights in your house then from there convert it to dc using 4 hevy duty diodes to rectafy the ac to dc so that i can adjust the belt speed. do you think that will work. it runs at around 3400 rpm at 130 volts dc. also my other question is it allredy has a weel type of thing atatched to the output shaft would it be ok to reshape this a little and use it to drive the grinding belt or does it need to be in conjuction with v pully and belt to drive another drive weel. i gess my last question is this, because i live in a apartment i want it to be small so i can take it out side to use but i want to use the 72 inch belts. i will post a picture of the motor later. thanks for your help
