Making damascus beads for lanyards
This is how I make the lanyard damascus beads you see on my knives/website.
Cutting a 1/2" x 5/8" damascus square section bar I've made for this
Some future beads cutted
Drilling a piece with a 5.5mm bit
Drilled piece
Threading it (1/4")
Screwed into a 1/4" threaded bar
Shaping the bead with a 60 grit belt
Roughly shaped
Now I'm gonna screw the bead into a screw to which I previously removed the head
I then place this into the bench drill
Finishing the shape with grit 80, then 150, then 220 and then 400
Polishing it to a mirror finish
Mirror polished bead
Supported with a bended wire, I then put the bead in a solution of 70% Ferric Chloride and 30% distilled water, for a minute, to check the damascus patterns.
Once I check out it's OK, I leave it there for 45 minutes to get properly etched.
Pictures of these same finished beads tomorrow :)
Sign up for my Newsletter:
http://server.com/WebApps/mail-list-subscribe.cgi?list=79955
Thanks for looking!
Ariel
Ariel, I know you guys are using the metric system over there, but I'm curious about something. Why the metric drill, but SAE threads?
BTW You do truly AMAZING work. I look at everyones, and yours is some of my favorites. Plus, you're kind enough to share you're methods. Too few masters are willing to do that. Thank you for it.
Question, Ariel. Do you harden the beads after shaped to get a better etch or just leave them annealed?
Once again Thanks for another great tip. You always have some great ideas and some great pieces. Jim
Thanks gentlemen, pics tomorrow (including a 1010/1070/copper mokume one)
We have tools from both systems, and since the threaded bar I have was 1/4", I've used my threading tool for the SAE system. :)
I do HT all my damascus pieces as it etches better.
Regards,
Ariel
