Making Imbira Bark Cordage (photos)
Imbira is a fantastic resource for shelter building. The saplings grow very straight and the bark can be used as is for lashing or made into very high quality cordage.
South American Indians use Imbira to make huge structures. Stripping the poles creates all the lashings you would need to make just about anything.
Technically I should have scraped off the grey outer bark first for making cordage, but I was initially only wanting to show how to use the bark as it comes off the tree.
If you make a single cut all the way down the length of the pole you can start at one end and strip off the entire piece of bark in one long piece. As soon as the sap makes contact with the air it starts to turn bright orange and it will stain your hands.
The lighter cord piece in this photo is about 5 feet long. If you just strip off the bark and leave the "casca" (outer grey stuff) on you can use the bark for lashing in whatever width you need. It will bind stuff but it is pretty stiff and when it dries it is very hard. The larger "rope" was made by twisting a single strip of bark, it was strong enough to hold my body weight (194lbs). Towards the end I split the thicker side into two strips and finished it by braiding it with the rest of the thin side. This kind of simple lash would be strong and long enough to lash a high stress shelter point such as a bed frame. If you find a grove of Imbira saplings you're home.
This shot from a Brazilian website (not my photo!) shows the type of shelter/house made from Imbira poles and bark They only last about 10 years, but the mortgage payments are real easy.
Now that's bushcraft!
If you scrape off the grey outer bark you produce a much suppler strap that is easier to work with once it is dry. This is the form you see most often being used as it is quick to make and still remains strong. When it’s dry it’s still pretty stiff but with rain and sun it weathers a bit and starts to look like flat rope.
Between the fibers of the inner bark there is pithy "filler" that contains the orange sap. Once it’s soaked in water you can scrape this out. With that material gone you can produce plaited cordage.
For making cordage there are easier, more uniform materials such as palm fiber. Palm fibers are round in profile and they roll against the leg easily. Most hammocks and such are made from palm. Imbira isn't often used for plaited cordage but when it is, it is exceptionally strong so its used for things like bowstrings.
If you are just building a shelter then the scraped bark is good enough and happens right now so that is the most gain for the least effort with Imbira.
My main goal in this project was to practice joining smaller pieces while plaiting the cord to keep it going and make cord longer than the fibers I start with. I'm finding my challenge is to keep the cord uniform in thickness as the bark strippings tend to have a thick and thin end.
Scraping the bark clean resulted is a large handful of short fibers that just scream "Friction Fire, dry me out and put a coal in me!" So Imbria can make a bowdrill cord and the tinder nest as a byproduct of the cordmaking process. It does light up with a ferro rod.
My son and I sat in the back yard and "made string". I'm getting the hang of making it as long as I want to, adding material as needed. This piece is about 15 feet long in the photo. My cord is now twice that length. In the center is the washed and dried scrapings from removing the outer bark, it looks like really good tinder. It does light with a ferro rod.
Mac
Pict,
Thanks! I really like "skill" threads and would love to see a tutorial on "doing the twist!"
Looks good :thumbup:,
What knife do you have clipped to your pocket?
Fonly, you knife Ho! :D
-- FLIX
Flix,
Here's a great tutorial on making cordage. It really is easy to learn.
http://www.primitiveways.com/cordage.html
The hard part is preparing all the material but once you get going it is pretty instinctive.
Ray Mears shows the technique on a few of his bushcraft videos. He starts his twist in the center of a ply of bark, which is fine if you're only making a short piece of string. If you want to add material and keep going, start your twist about 1/3 the way down your first piece of bark. That way one side will run short before the other and you can continue to add new strips in, alternating sides. If you don't start 1/3 down the first strip you will have to add material to both sides at the same place and the cord will be thick and weak at that point.
Here's something I've never seen mentioned. When you're all done a length of cord, say 15 feet or so, break it intentionally. Sounds crazy but the total string is only as strong as its weakest point, so let it break there. I did this twice with my 30 foot cord. That way once the ends are joined together the string is still only as strong as its weakest point but you have elimianted the points where you screwed up the worst.
The whole process goes much faster if you have someone else taking up the finished cord on a wooden stick and doing the counter rotation for you. They wind a little, twist a few times counterclockwise, wind a little more and keep even tension on the cordage. You just have to roll the plys clockwise and splice in new material. It also helps to keep the bark wet and roll the plys against your pant leg.
The diameter of bark cordage varies as much as 50% in thickness when made by people who are skilled at it, it is hard to make small bark strips that are equal in width and thickness. Cordage made from fibers like palm or yucca can be made much more uniform as the fibers themselves tend to be uniform.
I'm still looking for something like nettles but haven't ID'd any yet. Mac
Fonly,
That is a Tramontina knock-off of a Case USMC pocketknife, right down to saying "Can Opener" on the hook. It isn't a bad knife but it seems a little weak to me. It was in the door well of my car so I popped it on my pocket. I don't normally carry it but it has been growing on me lately. Mac
Fonly,
oh neat-o, It looks shiny so it caught my attention.
-- FLIX
What-cha gonna' do:rolleyes::D
funny:D
