I have some pieces of leather with blemishes on the smooth side, and I'm considering making a sheath with the rough unblemished side on the outside.
Are there any reasons why this shouldn't be done?
Go for it! No reason not too.I have some pieces of leather with blemishes on the smooth side, and I'm considering making a sheath with the rough unblemished side on the outside.
Beauty work, Dave! I’m gonna try rough out soon!Absolutely no reason you shouldn't and all kinds of reasons you should. I do a lot of work in roughout.
Combos work well too:
Our most popular spur straps by far:
Bout 50/50 on rifle scabbards:
And as some of these pics show its toollable to. I wouldn't do flower craving or similar as it doesn't hold that kind of detail but stamping works well:
All of our IWB holsters are roughout. Always have been:
Anyhoo. If your design relies on friction at all for retention, make it slightly tighter., maybe half a hair. I did a post here sometime back (years) about working with roughout, I'll see if I can find it.
Thank you sir!Go for it! No reason not too.
Ya bet. Let us see your work when you are done!Now I have to try it! Thanks!
I would agree with you for your environment. For being able to get leather as water resistant as possible smoothout is the choice. I'd not thought of the wicking properties of the rough fuzzies as you described. Very interesting.I don't build my sheaths with the smooth side facing inward because I've found that water will sit in there and rust my knife if I forget to take the knife out and let the sheath dry- it also seems to take longer to dry than the other way.
My sense is that the fibers from the rough side tend to wick moisture from the inside of the sheath outward. I regularly store my knives in their sheaths, and quite often don't dry anything out, even after working in the rain, and very rarely does that end up in a rusty knife.
I think rough out looks cool, and maybe has some advantages not readily apparent in the environment I live in, but apart from overlays I won't build sheaths this way.
Another one bites the dust:
