- Feb 17, 2007
I have been trying to learn to make makome. Had a thread going earlier and was advised to use a temp of 1900. I ended up with a puddle of yellow brass and some partially eaten up copper.
I tried again today. Here is how I tried. I took 6 2"x2" pieces of 1/8" thick copper and 5 pieces of 2"x2" of 1/8" yellow brass. All sides were sanded clean and then stacked and enclosed in a ss foil envelope with a small piece of brown paper. I then used a clamp I made. Two 1/2" plates of inconel 800 with 5/8 inch holes in all 4 corners and 4 1/2" 304 ss bolts. I clamped the package as tight as I could get it between the plates and hammered it a couple times on the anvil then retighted. I then placed the assembly in my kiln and set the pid to 1450 as advised by a member at Blade West. After about a 1/2 hour I shut the kiln off and after an hour or so removed the package and let cool. When I disassembled and opened the foil the copper and brass were stuck together, but sitting on edge a few taps with a hammer caused them to come apart. Inspection showed the copper plates had a light coloring of brass, but that was it.
I resanded the plates and refoiled, then clamped tight again. Set the pid on kiln to 1500 and went again. This time after a period at 1500 I opened the door and fished out the assembly, set it on the anvil and popped it a couple fair rapps with my 4# hammer. Let cool. and upon opening I found the plates in the condition as the 1450 soak.
Here is my question. Is my temp just to low or am I doing something else wrong? Should I just keep jacking it up 50f at a time? Should I hang a piece of the brass in the kiln and keep watching it and see what temp it melts at? Then just back off a bit from that? Any help appreciated thanks.
