Making mosaic pins/tubes
Hopefully this is right place for this... I've had limited success so far with making some simple mosaic pins for my knives...still in the early stages of figuring.g out what I'll want. That being said, there are a few aspects of the technique that are still eluding me. I've seen some pins were the internal pieces seem to float, like a tube within a tube, or the H in HHH's knife pins. I can't figure out how to get the pieces to stay in place while the epoxy sets up.
I'd appreciate help from anybody with some experience in this with some tips or tricks.
Like you I just began to try making pins. I have more luck making the pins knife width long , one pin at a time. Even as I build the knife. I hold inner tubes, wires in place with a little thin super glue. And or I allow the inner parts to extend beyond the outer tube to be trimmed later. Or I put tape on the end of the tube and inject glue with a throw away syringe from the top. The choices depend on the design. There are colored super glue products in various viscosities I like better then epoxy. They set up when I spray with the accelerator and it’d done before it drips out, (a finger over the bottom for 10 seconds).
Have two tubes, one whose inside diameter is the same as the outside diameter of the first tube.
Cut the first (wider) tube as wide as the handle will be.
Cut the second tube shorter and insert in the first tube.
Now you can put in what you like. (I like mosaic pins that look like a flower)
Fill the empty spaces with coloured epoxy and after drying sand flush.
Tadaa
Tadaa
That's a good idea! I may give that a try.
