I bought an oyster knife blank and wanted to fit a handle to it. I have never done this before so I knew there would be a learning curve.
I took a piece of 2x2 white pine and and cut off a 5" section and then cut it into two piece. I used a router to cut a channel for the blade tang and then shaped the handle with some sanding belts.
For finishing the handle, I used some Minwax Walnut and put four coats on it. I went to apply to Tung Oil and it rubbed some of the stain off and now it is very blotchy.
My question is, what am I doing wrong? Should I have just left the stain on there and not finish it? Let the stain dry longer? Or just apply the Tung Oil to the unstained wood?
Progression on the handle.
