- Mar 1, 2006
Hey guys,
Just got an 8 inch grinder so started grinding some 1055 carbon into a short sword. The steel was sold to me as annealed, and yesterday the grinder cut into it easily (making a chisel grind sword). The steel did get hot though, and I had to hold the steel wrapt in a t-shirt to keep working (there was a lot of purple going on there also). Anyway, went back to it today and I am certain I have hardened the steel as the grinder prefers to bounce off the steel a lot more. I also drilled some holes in the tang which was very difficult to do, in fact it burnt the drill bit. So the entire piece is hardened, not just the edge that touched the grinder.
Have I stuffed the steel now or can it still be heat treated properly? Also, I plan on getting a multitool for the grinder which is like a linisher attachment that takes belts like a belt sander. How can I ensure that I dont accidentally harden the steel for next time? The grinder does not have variable speed either.
Thanks
Thanks
