Hi, I'm new here, though have lurked and scanned threads.
I'm about to start working on my first knife, having done a couple practices on some mild steel. I'm just making sure I understand everything correctly, so I don't waste a good piece of steel (I'll be using 5160 steel, and doing stock removal).
Step 1: Cut out rough shape, grind rough bevel with a metal file.
Step 2: Normalize by heating to critical temperature and then letting air cool
Step 3: Repeat normalizing 3x
Step 4: heat to critical temperature
Step 5: Quench tip first in canola oil or motor oil or some type of oil
Step 6: Pre heat oven to 350
Step 7: leave blade in 350F oven for 2 hours
Step 8: Make a handle
Did I get everything right?
Also, is 13.75 inches small enough to heat with a propane torch? Or do I have to use a charcoal grill (I don't have a forge)?
Thanks in advance.
Thanks in advance.
