Have only built the following so far and there is much more to go...
-2X72 VFD grinder
-table similar to MAP arm
-9" disk grinder
-knife vice
-filing station
-hardened filing guides
-copper clad sanding sticks
-electro etcher
-cyro tank for use with acetone/dry ice that holds -100 F for 8 hours
-air filtration system
-one horizontal forge and one vertical forge
-salt pot
-rolling anvil stand
-rivet flairs for kydex sheaths
-kydex press
-electric heat treat oven
-mini 20 ton press
-compressed air distribution system for entire shop
-welding bench
-pin press
-emergency stop systems for various machines
-quench tank
-portable PID that can control whatever I plug into it (e.g. temp in quench tank, salt pot, forge temp, temp of my coffee or simply taking a forge temp reading in a non-temp controlled forge)
-wood dehydrator that doubles as a fermentation heat regulator when brewing beer for the shop fridge. :thumbup:
I'm sure there is more but, that is all I can think of right now...
Eric
