I started this project with the intention to find a workable material that I would be able to shape into a functional knife,machete,and kukri scabbard with a minimum of effort and a minimum of technical skills.
I wanted something that had the following characteristics:
1- Very lightweight
2- Extremely durable
3- Resistant to the blade cutting through it
4- Easy to form and mold
5- Cheap
6- Waterproof
7- Unbreakable
8- Thin
9- Easy to carry in a pack,on a belt or shoulder sling
10-Dual use and easy constructed as a scabbard for machetes,knives,kukris or goloks
I believe I found the near perfect material at the nearby Lowes Store.
It is named:
Plastex waterproof wall panel
.060 x 4' x 8'
Bright White
Made by Parkland Plastics
Website:http://www.parklandplastics.com/
Cost for a sheet was $14.24
Stock # 72405
The other materials I needed to start my custom scabbard making project were:
1-A hand riveting tool for blind pop rivets
2-Aluminum rivets--- $5.99 for 100 pcs
1/8" diameter
Grip range-1/16" - 1/8"
3-Backup plates aluminum for use with all brands of rivet tools 1/8" diameter--$1.49 for
30 pieces
4-A pair of tin shears, Prosnip wirecutters Model 20SL, or a pair of heavy duty scissors to
cut the material to scabbard shape.
5- A Dremel tool with a 1/8" bit for drilling the rivet holes
I just finished making my first four scabbards this afternoon so this is another learn by trial and error adventure but so far I am EXTREMELY pleased with the results. Mind you, these are by no means beautiful works of art but they sure are light and practical and the material is so easy to work with.
I think in a comparison with almost any of the other scabbard materials such as wood, leather, kydex, etc. that plastex will hold it's own.
I hope that someone who has a heavy duty sewing machine will post a report on it's sewability.
Here's how I'm proceeding: I initially lay the knife, kukri or machete on the plastex and outline it with a magic marker.
Then I increase the outline about 1/2" to 1" around the perimeter of the outline so I will have a place to put the rivets in in order to rivet the two scabbard sides together.
Then I use the dremel tool with a tiny 1/8 " drill bit to drill the rivet holes. Then simply put in the rivets.
I have not decided how I want to do the belt loop or carrying loop yet and would be grateful for any ideas. It appears that the plastex can be slit to make a belt slot or looped and riveted whichever is preferred.
I have never worked with this material before but there are some chemicals listed on the website that can be used if rivets are not wanted.
I selected aluminum rivets because they resist rust and the blade,when sheathed,won't cut through them.
There's one thing for sure, with a 4 'by 8' sheet of this stuff you can experiment til the cows come home and still have a bunch left over.
1- Very lightweight
5- Cheap
6- Waterproof
7- Unbreakable
8- Thin
It is named:
.060 x 4' x 8'
Bright White
Stock # 72405
1/8" diameter
30 pieces
