- Jan 10, 2001
Oi Vey Mir - Where to start?? Bad first: Chos on karda and chakmak were rough. Good chance to use new set of diamond files (they don't bounce off of hardened steel like test files). Yes, they do. Dremel tool and extra-fime Cratex worked like a charm.
Cracked handle: Super glue worked as advertised. A little sanding dust on top almost makes it invisible. Typing with three fingers glued together is something else.
Handling: Superlatives go here, but haven't found one high-powered enough yet. Super Sirupati comes to mind, as does Kobra Lite Magnum, but they are only close. I'm afraid that when the right one comes to mind, it will be enthusiastic but unprintable. The handle is exactly the same diminsions as the 25" Kobra, and the control over the shorter blade is fantastic. Balance is about 2 3/4" forward of the cho, and just right for blade length and weight. This is one fast puppy!!!
I like my 12" Sirupati and AK, but if I can make my hideout sheath into a high-ride, this will be my choice for walkabout. It of course has many other uses, but first time out of the sheath, it says "Fighter". It will be a while before I play with any other blade.
How long does it take for skin to grow? I can't hold a coffee cup like this.
[This message has been edited by Walosi (edited 05-24-2001).]
