Curse you bladeforums! I ordered an S110V Manix 2 yesterday after reading some of these threads and can't wait to get it. It sounds really impressive, and for some reason I've been preferring the FRN over the G10 Spydies now. Can't wait to get it and see what it can do.
What grit did you start with on the reprofile? I am assuming you used the EP. I got mine yesterday, and the S110V Manix (once it dulls enough) is going to be re-profiled.
So would the 220 EP stone be fine, or should I start with the 400?320 grit Congress Moldmaster SIC.
I found the 220 EP does not cut very fast, I never use it. I much prefer the 120 EP, its a SiC stone and is much more effective on the high carbide steels.
I usually do 120, 320, 600, SM brown micro bevel.
Normally I like to reprofile lower than 15 dps, like 12, and then run a 15 dps micro.
Yes those thick grinds are quite a pity IMO, I really wish Spyderco would give us thinner grinds.
Like some senor who tried to pry firewood apart, and broke the blade through the thickest part of the tang...
Yes, that little stunt did not help our cause...![]()
I have broken enough folders over the years myself, it's not really all that easy.
He had to really be yanking on it hard....
are these in stock anywhere?
