Lil TimmyDisappointed how?
phatch said:Only paying members can vote in polls.
Phil
The blade is 3/16", the same on on the custom Striders, the tip has a very acute profile and would break readily under lateral loading, however the lock is vastly more secure than liners and integrals under impacts and torques and thus thicker blades on locks of that type are problematic as the lock doesn't match the strength of the blade.OwenM said:it's almost funny to see such a thinly ground blade on an overbuilt handle being embraced by the "heavy-duty" crowd just because of a strong lock.
A big knife can do the work of a small knife, but a small knife cannot do the work of a big knife.WadeF said:The Manix is a great knife, but it's BIG.
Chuck Bybee said:A big knife can do the work of a small knife, but a small knife cannot do the work of a big knife.
I've been carrying a Manix for a couple months. The handle was too small for me. I modified the handle to fit my hand.
UltraSteele said:... though of course its also twice as expensive...
In the overall scheme of things, yes.WadeF said:So bigger is better?
This may be a person problem. The differences in size and weight are not that much. However, if the difference are so big that you are annoyed, that is your choice.WadeF said:Even when it's uncomfortable in my pocket and annoying the F#(@ out of me?
Will it do the work of a gentleman folder, yes.
Using your example, could a 10" knife be used for emergency surgery, yes but ineffectively. Could a scalpel be used to chop firewood, no. Toothpicks maybe.WadeF said:I don't see many doctors using a 10" bowie knife to operate. They tend to use tiny scalpels.
Chuck Bybee said:My EDC gets used very hard. I trim calluses, clean fingernails, scrape wood, cut wood, separate wood blocks that are stuck together, scrape welding spots off my glasses, cut cardboard, strip wire, cut metal banding, cut plastic banding, scrape labels, etc. I do lots of the jobs while wearing gloves. The Manix opens, closes and takes a beating and still works great.
It isn't an issue in any case unless you are actually beating on the handle, impacts to the blade, prying, torques and so on will damage the blade and/or lock mechanism before even FRN handles get damaged. If you don't like the look of platic that's a personal choice, but it is hard to argue against it from a durability perspective. The only real issue is that some times micro screws are used which can shear through FRN much easier than G10.WadeF said:I think someone talked about using the Ritter Grip to baton (split) wood. Since you are wacking the blade the handle strength shouldn't be an issue if proper technique is used.
