Not to much use, just lived in the pouch pictured with the battery capsule.
Specs from Country comm site below
you will get the one light, battery inside if you would like, the battery vault with battery inside, two of the battery carries picture in stock photo and carry pouch
$42 dollars shipped
Specifications:
Length: 2.78"
Diameter: .76"
Weight 19.3 Grams / .68 Ounces without battery ( Incredibly lightweight )
Black Hardened Steel Pocket Clip ( Easy to clip onto a hat, MOLLE gear or shirt pocket )
Glow In the Dark Built In reflector ( Easy to find in the dark )
LED Type: Cree G2 Emitter ( High Output ) with a life span up to 50,000 hours.
Flashlight body is made of Aircraft Grade Aluminium
Stainless Steel ring around the dome lens for added durability
The dome lens has been treated with a AR (Anti-Reflective) coating.
Proprietary circuit design features reverse polarity protection and runs off of one AA battery that provides 3 levels of brightness ( Low /Medium / High).
Using A Single Duracell AA battery we got the following results:
Low Mode, 5 lumen output for upto 100 Hours ( Diffused Light )
Medium Mode, 40 lumen output for upto 7 Hours
High Mode, 135 lumen output for upto 90 Minutes
Limited First Run
All Gone Until Febuary 2016
$42 dollars shipped
Specifications:
Length: 2.78"
Diameter: .76"
Limited First Run
