Maratac SR35 DLC X1 Diver price drop
Feedback: +20 / =0 / -0
Catch and release, never worn, wound once. $300 shipped USPS Priority CONUS. PayPal Friends and Family / Gift only. Additional shipping charges to your destination -PM me. First 'I'll Take It’ gets it. NO TRADES.
https://countycomm.com/collections/...ck-pvd-sr-35-diver-automatic-watch-by-maratac
( LIMITED PRODUCTION OF 100 PIECES )
2 NEW UPGRADES
1. NEW UPGRADED - DLC BLACK - HARDER & TOUGHER THAN PVD
THERE ARE TWO MAIN OPTIONS WHICH CAN BE USED TO COAT STEEL, PVD & DLC COATING. DLC OR DIAMOND-LIKE CARBON, IS A DIFFERENT WAY TO USE THE PVD PROCESS. THE MAIN DIFFERENCE BEING THAT INSTEAD OF SPRAYING ON A GROUP OF METALS, DLC USES A FORM OF CARBON. ONCE THE CARBON IS BLASTED ONTO THE SURFACE, IT IS COOLED DOWN EXTREMELY QUICKLY, WHICH IS VERY SIMILAR TO HOW SYNTHETIC DIAMONDS ARE MADE.
2. NEW SWISS SUPER-LUMINOVA® GRADE X1 = 60% BETTER PERFORMANCE THAN BEFORE. NOW THE LUME WILL GLOW FOR BRIGHTER AND LONGER THAN EVER BEFORE.
DLC is a process which makes the steel harder and more corrosion resistant with a thin film of Carbon. Other benefits include increasing wear, scratch and corrosion resistance making its durability far superior to conventional coating methods such as electroplating or powder-coating.
Maratac™ automatic watch with Hacking Seiko NH-35 Movement
Ceramic Bezel Insert With Super Luminova C3 Phosphorus
- Highly Scratch Resistant And Durable
- Wont Fade With UV Exposure
- Chemical Resistant With Anti Magnetic Properties
The Maratac™ SR-35 Mid Divers Automatic watch is privately designed. The SR-35 is Maratac's newest mid size watch into the hacking ( stops the second hand when adjusting the time ) movement market.
The SR-35 features a unidirectional 1 hour timing bezel. This watch is made to exemplify the purest form of time, which provides a simplistic feel to the watch. The SR-35 utilizes a Seiko NH-35 24 jewel movement known for its superior quality, accuracy and of course it's hacking feature. This movement provides up to 40 hours of power reserve when not in use.
This mid size watch is ideal for both formal and casual events, and is built to last with it's robust sapphire domed crystal.
This is another clean and simple design by Maratac™
Watch Details:
DLC - Coated
Ceramic Bezel Insert - Extremely Durable / Zirconium Oxide
14.4mm Thick & 40 mm Diameter Case
The crown is positioned at the 4 o'clock marker for both left and right hand wear
Case: 316L stainless steel case, cut from a solid block.
Weight: 86.4 grams
Dial: With Swiss Super-LumiNova® Grade X1
Hands: Swiss Super-LumiNova® Grade X1
Matte finish ( Triple Applied X1 )
Second Hand : ( International Orange Pantone : O21C ) + Luminova C3 marker
Strap: Nylon Maratac Strap
Movement: Seiko NH-35 Automatic / Self Winding ( Hacking movement )
24 Jewel movement ( 21,600 Vibrations Per Hour )
Water resistant: 10 ATM
Crown: Conventional Screw Down Crown
Shoulderless Spring Bar
Sapphire crystal domed
Fits all 20mm bands ( Single and 2-piece band compatible )
