Selling my Marathon TSAR to thin down the herd a little. I would rate this between 90-95%. It comes with box, papers, bracelet with US Seal, Marathon rubber strap and Nato strap. As always I will return your money if you are not satisfied. Specs are below pics.
Feb 2006 contract date
Serial # 0992
$425 shipped- Postal money order only and no trades please.
Movement: ISA QUARTZ 1198 High torque quartz module
Dial: measures 27.7mm and utilizes Tritium vial technology
Crystal: sapphire - 2.8mm thick x 30.50mm diameter
Case: is cut from 316L stainless steel
Case diameter is approximately 46.0mm
Bezel diameter is 41.10mm, milled engraved and filled
Case Height is 13.85mm
20 mm lugs with drilled holes
Crown: 6.5mm dia x 5.50mm long, deep knurled
Date: between 4 and 5 o'clock on the dial
Serial # 0992
