Yeah I know what type. I need the bit size. Thanks.
They're the tri-angle screws. Same type found on current Halo V and Combat Troodon models, just a different size.Why don't you tell us what type, so we all can learn. We're all just taking random stabs in the dark until you at least tell us
what shape they are.
Thanks.Just email Josh, the owner of pvk.com. He has the biggest variety of Microtech/Marfione tools that I have found. He hooked me up with my pivot adjustment bit for my Marfione Socom.
The bit below looks close.. But like it says, call or email for questions on getting the right one. Good Luck!
Combat Troodon uses the medium bit and the Halo V uses the small. Can't find a size between. Thinking they don't have a proper size bit for the Sigil...Do you know the size of the combat troodon or halo IV either? If you did, I assume you could try bits that are numbered in between those two sizes... >_>
But would it surprise you if this semi-custom (custom?) Marfione used a particular shape and size of screw that wasn't used in any other Microtechs??
I just assume every Microtech model requires it's own unique tool which must be purchased from Microtech![]()
