marlin papoose
I carried a Henry (AR-7) as a backpack rifle for a long time I've seen the good with the bad, the bad, a shell casing got stuck between the bolt and the roof of the receiver, it took some time but I found out what happened when I was cycling the bolt and a mangled shell fell out.
The good is that I got absolute reliability with the sub sonic .22 ammo like aquilla, it turned the Ar-7 into a single shot, bolt action rifle, but I never had a malf after I switched to that ammo.
Sorry to hear about the problems with the Marlin. Someone here also mentioned the ar-7 as an alternative. I had a Charter arms ar-7 (for over 10 years) but its one of the possessions i sold a few years back to help pay tuition.I think it can be a good gun taken within the limits of its intended purpose- as a lightweight foraging survival rifle.
The one i had was deadly accurate. The super lightness and easy stowability made it the perfect backpack gun. However mine would never reliably feed hollowpoint or truncated point ammo. It was strictly a "lead round nose" kinda gun. The standard magazines were super reliable but i never found an aftermarket extended mag for it that would work reliably. Also after about 50 rounds the barrel nut/takedown nut would start to loosen. If you intend to do a serious amount of shooting you need to remember to hand tighten the nut after 2 or three mags. Really the ar-7 is not designed to burn through a 1000 round brick of 22's in an afternoon. However regarding cleaning and detail stripping i found the ar-7 to be fairly simple and robust. As a backpack gun it can be ideal however if you want a super reliable all round 22 go with the Ruger 10/22.
That being said i do want to try the new Henry ar-7's. The Henry company certainly has a great customer service rep.
Actually I requested a catalogue from them last year and a few weeks afterwards i got an email from the company president making sure that i got my catalogue!
That kinda impressed me!
I have a Marlin 60 (had it for two decades) and it never jams. I have heard of problems with the barrels nuts on both the Papoose and the AR7s from various manufacturers (Armalite, Charter, and Henry).
I'm leaning towards the small Henry H001 lever action. Very small, light and feeds .22 long rifles of all types and .22 shorts if I want something very quiet. Because it has a tube magazine, I don't have to worry about finding reliable magazines, a problem that plagues the 10/22.
I've never found the 10/22 to be reliable and ruled it out long ago. And like most other Rugers (Mini14), they are very inaccurate unless you put an aftermarket bullbarrel ($200+) on it. 10/22 does have lots of aftermarket support. If you want to put several hundred dollars into it, you can make it into a play commando lookalike gun. I don't know why, but some people do.
That being said, it would probably be good enough for foraging. Shoot it first if you can to see if you can find one of the more accurate ones. Like everything else, it seems, the older ones are reputed to be more accurate adn reliable. I do like the very short carbine version with the 16 inch barrel and shorter stock.
The takedown aftermarket stock for the 10/22 isn't being made anymore.
That's not that uncommon. Many .22 autos don't like HP's for some reason. I had an automatic pistol like that once. All it took was a little time spent polishing the feed ramp with emory cloth and removing a bit of the lip on the end of the feed ramp to get it to function fine. Not saying that would have fixed your problems, but it is worth the time.
Most 22's are going to be somewhat ammo sensitive. Shoot a few different kinds to find out what your rifle likes.
