- Oct 26, 2006
Hi guys, I have been doing some forging of A2 for a while, and I noticed something that I stumbled upon, that I was hoping you could help me understand a little better, and to share with you.
When I forge A2, which I know to be an air hardening steel, the steel gets harder with every heat. I then marquench it in oil, then temper at 400 for an hour, then at 425 for an additional hour. The A2 comes out unbelievable with this process; very tough and holds an incredible edge.
Which now brings me to the point.... I made a stock removal knife for my daughter using the A2, marquenched, then tempered as above, but....it did not hold the edge for as nearly as long as the forged blade.
So, I had the idea to try and "fool" the A2, by using simulated heats, as if I was forging the blade. Bright orange....black heat....bright orange...black heat...etc., then marquenching it, then finally tempering it.
Well....wouldn't you know it...IT WORKED!!!
Now, did this work only because A2 is an air hardening steel, meaning it got harder after letting it cool to room temperature after the marquenching? (As well as it getting harder between heats.) Would this work with 10xx steels as well? At least the repeated heats would refine grain structure, right?
Oh yeah....one more thing. Why do many people say to temper A2 at 500, when, when I temper at 400, then 425, it comes out unbelievable? Is it because of the marquenching? Does the marquenching relax the steel to the degree that it's "softened up" (so to speak) prior to the tempering?
Thanks.
- Mitch
Thanks.
- Mitch
