Massive Purge - NO trades Please
luethge
Feedback: +593 / =0 / -0
Hi Blade Forums,
This post is going to be a a little messy. I am going to be adding more pics sooner than later.
I am Not looking for any trades at this time - absolutely need to sell these and more will follow as these go.. making that elusive attempt to keep only dedicated users.
I have no idea if or when feedback ratings will return - I had 506 positive and zero negative or neutral prior to BF software update.
I will accept PayPal, Zelle, postal money order or Venmo. I greatly prefer friends and family but I will accept goods and services - prices will be adjusted accordingly.
Prefer shipping to USA 50
Canada is a possibility but shipping is on buyer. Prices have skyrocketed lately - recently spent $50 to mail two knives domestically.. that stings.
I WILL NEVER SEND YOU AN EMAIL REQUESTING PAYMENT. IF YOU RECEIVE AN EMAIL REQUESTING PAYMENT YOU ARE ABOUT TO BE SCAMMED - DO NOT SEND FUNDS TO ANY EMAIL REQUESTS.
I’m going to attempt to give descriptions top to bottom, row by row and folders last - please forgive the upcoming confusion.
SOLD Becker/Esee collab: 1095 steel, 5/32 ish stock, 3.5 inch blade, knife connection G10 scales, aftermarket Kydex sheath, spyderco Gclip. Edge has been tuned up and it’s pretty sharp. Will include original sheath but the kydex one is superior in every way. Very little use on this one.
$65 F/F
$70 G/S
Kim Breed Tactical hunter. 80crv2 steel, 3 7/8 inch blade , .20 stock, differential heat treatment, vintage Westinghouse micarta, hollow primary grind with a flat ground stout tip. This one has been used, sharpened, carried, used, used, used and sharpened. Will make a great user.
$200 F/F
$210 G/S
Brock Blades Outdoorsman.
3V steel, 4 inches tip to scale, .110 stock, hollow ground ( this one is a razor ), G10 scales, makers kydex. I sharpened this one once at 20 degrees per side - could probably tolerate going to 14 per side without issue. This knife is thin - thickest part of the knife and scales is about 5/16 - does not print when carried IWB. Excellent utility / defensive / hunting style.
$280 F/F
$300 G/S
SOLD Battle Horse Knives Bushcrafter.
01 steel, 5/32 stock, full height convex is well done, polished black canvas, loveless bolts, black / white tuxedo liners, perfectly molded JRE sheath ( one of the older and seemingly nicer ones ). This one is used, not abused, has plenty of scuffs and a beautiful patina. This is one of the best performing knives I’ve ever had - rivals a Scandi in wood carving but it cuts everything else too. Beautiful piece.. not super rare but you don’t see them very often either.
$135 F/F
$145 G/S
Withdrawn Seved Knives Survival. Made is Norway, 5160 steel, forged, full height convex, micro secondary edge, green canvas scales w red liners, blade is about 5 inches tip to scale, .24 stock at the ricasso spine. This one has carried and used - it’s in excellent condition though. Scuffs and scratches but no chips or rust. Comes with a very simple Kydex sheath and a leather sheath for right hand carry. Definitely a little big knife - skull crusher pommel should make short work of anything needing crushing.
$130 F/F
$140 G/S
On Hold Ed Martin B/T (bushcraft tactical).
80crv2 steel, 4.75 inch blade, 5/32 stock, convex grind, natural micarta scales, not sure is the guard is stainless or aluminum- it’s rock solid though. This one is used, carried, sharpened, scuffed, scratched, used, sharpened and loved. I’m the original owner of this one. Includes makers leather sheath / rig and a few add ons: micro fire steel and enough paracord to be very helpful in a bad situation. I will probably be pulling this one soon - act fast if you want it.
$300 F/F
$330 G/S
SOLD Newt Livesay ICU ( may be an Air Assault model ). Catch and release. This is a well used knife. I started to fix the rounded tip with diamond stones, started to clean up the edge, started to reprofile the secondary - then I realized this is a Livesay knife.. it’s supposed to be ugly, dirty, abused and used for knife and non knife related things. This will make a great user, I’ve got two so one must go. 1095 steel, Black and green canvas micarta, loveless bolts, differential temper, hollow primary with a flat ground tip, 3/16 stock and blade is just under 5 inches. Will include the Kydex sheath Newt made - being from the 90’s though and visibly warped ( probably sat in a hot truck for a while) - the sheath is worthless. I may be able to scrounge up something though.
$115 F/F
$125 G/S
SOLD Utility Tools Oregon. Catch and release. A2 steel, just under 6 inch blade, .20 stock, full flat grind, micarta scales, beautiful leather sheath ( Obenauf coated x 2 ). Edge has been touched up, I took the scales off to oil the tang - managed to strip the middle bolt - you will need to add hardware to the center hole - the top and bottom are fine though. Parkerized finish is worn away at the tip / swedge - one of the original owners semi sharpened the swedge - maybe added black paint pen to cover the bare steel. Tip is intact, edge is sharp, grinds are perfect, handle is comfortable and encapsulates the tang - very warm to the touch.
$115 F/F
$125 G/S
Esee 6. 1095 steel, 6.5 inch blade, 170 stock, micarta scales ( can add 3D G10 if requested ), LT Wright ( TKC ) Kydex sheath with leather backer -( can also add original molded plastic if requested ). Very little use.. chopped a few sticks, cut up some meat, stabbed into a tree stump etc. I horde Esee 6’s and 4’s - gift them to close friends and hide them in bags - everyone should have one of these great beaters in an emergency kit.
$115 F/F
$125 G/S
Robert Erickson Custom.
Magnucut steel, 5/32 stock, 5.25 inch blade, very thin behind the edge - this one cuts and carves like a beast. Vintage edge cut micarta. Mild user has scuffs and scratches. I believe this one is at 62-64 HRC. Very comfortable handle if you have large mitts.
This one is pending for now
$ F/F
$ G/S
SOLD Real Steel Chieftain ( TOP’s).
1095 steel, 7.5 inch blade, .25 stock, natural canvas scales, white liners. This one has been used for chopping dry wood a lot. I was completely surprised how well this knife cuts, chops and stays sharp. Absolute beast of a knife - Hits hard, moves fast, looks terrifying- solid as it gets. Plenty of coating ware. Will come in a BK7 sheath and the original tops sheath. I may pull this one also.
$125 F/F
$135 G/S
THANK YOU BLADE FORUMS
Folders will be listed in proper section here https://www.bladeforums.com/threads...ss-spyderco-and-emerson.2010441/post-22826410
Will you trade for money?
We could work something out for sure. Would have to be American made money that is immune to inflation and pours black espresso shots though. Possibly money in the form of a RMJ Tomahawk 😂.
