Depends on the steel type. Generally between 15 and 17 deg is good for edc. Some steel would work fine at say 12 deg but may chip or roll easier.I've been seeing a bunch of tests recently showing the effect of a 'thin' edge angle on edge retention. Has anyone done a study to find the optimum compromise with 'real world' cutting such as ham-fisted blokes like myself might be doing with EDC type usage? I assume it's thinner than factory but wider than entirely optimum for a controlled machine test.
To summarize: Using a Spyderco knife in XHP at a 30° angle, he tested push cutting cardboard with a coarse finish and also a polished edge finish. He saw a 15% improvement with the polished edge. I believe that it was one test each so I'm not sure how much variation there would be if he were to do three tests per condition, for example. He also had text stating that he stopped cutting when it would no longer shave, I believe. Regardless, there is evidence out there to suggest that a polished edge is better for push cutting edge retention and this is in line with that.
Controlled studies looking at the effect of edge angle on how easily they are deformed or chipped are in relatively short supply. But even with a very good study you still have to determine what edge angle is appropriate for your knife, steel, heat treatment, and use.
There were only two tested at 20° and those were at 120 grit. They were indeed run at the end.Follow-up questions:
Larrin Am I reading that correct, that there were only 2 blades tested at 20', and both were sharpened 120-grit? I must admit, I am disappointed that the data on 20' is based off of n=2.
Perhaps you do not know this, but I am guessing that those 20' blades were run near the very end just as a quick test to optimize performance on the CATRA machine, as they utilize the both the lowest edge-angle and the coarsest grit?
If you email me I can send you the final table in Excel.It would be nice to have the graphed-out performance of the 27' edges to compare against the 34' & 50' edges, as that seems to have been the intent of the study... or to have that final table in excel or some other format to quickly/easily transfer into graphing software so as to run the analysis with the limited information there given (obviously losing all of the data points of the curve of cutting performance).
I created a regression equation as part of creating the table with the effect of different parameters on R2. I don't think I saved it though.Finally, did the authors come up with a mathematical description of the relationship between edge-angle and CATRA performance similar to what we have for mechanical advantage and edge-strength?
Email sent via your webpage!There were only two tested at 20° and those were at 120 grit. They were indeed run at the end.
Though it’s not the way the industry has been moving, there have been people out there preaching the merits of acute edge angles and easy-to-sharpen steels for a while. My personal experience has also been leading me to the same conclusion, although without scientific rigour.
Thanks for posting this, Larrin.
