Maxpedition Jumbo Fatboy G.T.G. Versipack - Left-side carry, Khaki
SALTY
Feedback: +157 / =0 / -0
I cannot call the item "new" because I did put gear it in and hung it over the headrest on the back of a vehicle seat ... but I can call it uncarried. It is certainly as-new. It is the Tan/Khaki in the pictures.
Here are specs copied off of the internet.
Main Compartment: 6.5" (L) x 3" (W) x 8" (H) with drainage grommet
Front Pocket: 5" (L) x 1.5" (W) x 6" (H) with slip pocket and divided elastic admin organizer
Rear Compartment: 8" (L) x 7.5" (W) with 6x8 loop field to accommodate Hook & Loop Modular Inserts
Zippered Side Pocket: 3" (L) x 1.5" (W) x 6" (H)
Water Bottle Pocket: 3" (L) x 2.5" (W) x 6" (H) with adjustable cord retention
Belt loop: Quick detach for up to 2.25" belt
Shoulder strap: Integral 1.5" strap with adjustable non-slip pad; D-ring for lashing; maximum circumference approximate 60"
Carry handle: Integral 3/4" webbing
Tough PU-coated 800-denier nylon fabric for approx. 25% weight reduction
Teflon fabric protector for grime resistance and easy maintenance
high strength zippers and zipper tracks
UTX-Duraflex nylon buckles for low sound closures
Triple polyurethane coated for water resistance
High tensile strength nylon webbing
High tensile strength composite nylon thread (stronger than ordinary industry standard nylon thread)
#AS-100 high grade closed-cell foam padding material for superior shock protection
Internal seams taped and finished
Paracord zipper pulls
Stress points double stitched, Bartacked or "Box-and-X" stitched for added strength
MAXPEDITION's nylon fabric is treated with Dupont Teflon for superb water and grime resistance.
To clean, simply wipe down with a damp cloth. Allow gear to dry naturally.
Do not machine wash.
Do not use detergent or bleach.
$50 (net) shipped CONUS
