Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Take a small folding knife blade, that measures 3/8th high by 3/32 thick at the spine ; a blade with this geometry can sport a bevel grind that measures 2 degrees per side. This blade can be sharpened using an angle of 3 degrees or 6 degrees inclusive at the edge measured from the center line. This grind makes for one scary sharp folder blade
Yes, but regardless of how thin the blade is and how low the bevel angle is, the edge angle will not survive on a folder at 6° inclusive.
I make sashimi blades with bevels that are around 2-3° inclusive. While that makes a super thin slicer, the edge angle is still sharpened around 10-15° inclusive. If it was more acute, it would be too fragile. I doubt you could tell the difference in the first few cuts between a 6° blade and a 15° blade, but after fifty cuts, the 6° blade might appear dull, while the 15° blade will still be scary sharp. There is such a thing as too sharp.
