OilMan
- May 6, 2004
Medford's warranty has changed quite a bit since when this was originally posted, now your warranty isn't automatically gone if you take it apart.. But he STILL might make a video to complain about you. And dealing with his wife on warranty issues is still not as easy as it should be IMHO. He's also branched out to some different steels in the meantime..Will this special grease last forever or will you have rust and corrosion around the pivot after a few years or weeks?.....which is completely preventable with preventative (void medford warranty) maintenance. 7 hundred for d2 uncoated steel folder, I feel you should be able to grease/lube non exposed blade areas.....so you can pass it down to the kiddo
