The Meizu Pro 6 Plus smartphone is powered by 2GHz octa-core Exynos 8890 processor and it comes with 4GB of RAM. The phone packs 64GB of internal storage cannot be expanded. As far as the cameras are concerned, the Meizu Pro 6 Plus packs a 12-megapixel primary camera on the rear and a 5-megapixel front shooter for selfies. The Meizu Pro 6 Plus runs Android 6.0 and is powered by a 3400mAh non removable battery.
Main Parameters:
Display: 5.7 inch 2K super AMOLED ( 2560 × 1440 pixels ) On-cell screen with 518 PPI and 30cd/m² brightness
CPU: Exynos 8890 processor, 2.0GHz × 4 + ARM Cortex-A53 1.5GHz × 4
System: Android 6.0
Storage: 4GB RAM + 64GB ROM
Cameras: 12.0MP back camera and 5.0MP front camera
Bluetooth: 4.1
SIM Card: dual SIM dual standby, dual nano SIM cards
WiFi: 802.11a/b/g/n/ac wireless internet
Wireless Connectivity: 2.4GHz/5GHz WiFi
Battery Capacity: 3400mAh
Product Features:
● 5.7 inch Screen with 2560 * 1440 High Resolution
With the upgrade to a Quad HD resolution, we also improved the screen's brightness, color reproduction and contrast. The new AOD (Always-On Display) feature enables you to check the time, date and battery status easily.
● Consummate Craftsmanship
An exquisite micro-arc design and a redesigned body curve which takes over 30 steps and 150 hours to craft. All of this includes unique details such as the CD line camera, ring flash and minimalistic antenna design.
● Exynos 8 Technology
The Exynos 8 processor enables to run any large-scale or demanding applications you'll throw at it. With a frequency of 2.6GHz, the Exynos M1-core is combined with efficient SCI Samsung architecture and a powerful 12-core GPU.
● Create High-quality Photos
The new CD pattern technology allows the camera to take stunning pictures. 4-axis optical image stabilization with ƒ/2.0 large aperture and 6P lens produce brilliant photos at nighttime. The latest generation high-performance ISP image processor also significantly improves color, sharpness and noise reduction in photos and videos.
● Latest Generation Hi-Fi Setup
Aside from including the established ES9018K2M DAC, using the AD45275 chip for low power consumption. The unique XFCB technique enables to perform exceptionally while being energy efficient at the same time. The 180MHz gain bandwidth and 225V/μS slew rate makes the Pro 6 Plus among the longest lasting devices on the market.
● 3D Press Innovation
The popular 3D Press function can show an app preview by pressing the button, linear gravity calibration was also added.
● Fingerprint Accessibility
Optimized the fingerprint recognition speed and recognition rate to offer an improved overall accessibility. It can effectively identify the fingerprint in any direction, and being based on Live Finger Detection technology, the fingerprint scanner is more accurate than before.
● Health Monitoring
With the leading technology full 360-degree precision in fingerprint identification, your heartrate can be monitored at 50 times per second.
● Type-C + USB 3.1
Incorporates the latest USB standards: Type-C and USB 3.1. The USB Type-C connector no longer distinguishes between which side is up and which side is down, and supports a transmission bandwidth of 5Gbps, which means 1GB of data can be transferred within 10 seconds. The data cable has also been redesigned to support up to 60W charging.
● Faster and Longer-life Battery
Fast-charging batteries with a total capacity of 3400mAh, lifetime of over 900 cycles, which is about 2 times more than ordinary batteries.
The Chinese & English version is available on GearVita now: https://gearvita.com/meizu-pro-6-plus-4g-smartphone-4gb-ram-64gb-rom-chinese-english-version.html
You may like:
xiaomi mi 8 lite 64gb smartphone global version
xiaomi mijia quartz smartwatch
Main Parameters:
System: Android 6.0
Bluetooth: 4.1
Product Features:
● Health Monitoring
● Type-C + USB 3.1
You may like:
