- Jan 11, 2007
TRADED
MercWorx Proeliator in CPM S30V - new
The Proeliator is latin for the word warrior and is the largest Mercworx combat knife. Slightly longer than the Equatorian it is engineered for maximum chopping power and field versatility. The blade is cut from CPM S30V steel and then hand ground with the traditional Mercworx recurve. It also has a slight recurve on the top of the blade to further extend the cutting surface of the knife. The blade is hollow ground for a cleaner cutting and longer lasting edge. With a slightly leaner profile and handle, the fit and speed of the Mercworx Proeliator are the focal points for this imposing fixed blade.
Designed for extreme heavy-duty use, this is about as tough as a combat knife can get. Engineered for maximum chopping and thrusting strength. The ultimate survival-tool, bred specifically for the harshest survival challenge imaginable. The PROELIATOR is another MercWorx “truly one the best of knives, for the worst of times”.
Specs:
OAL: 14 1/2" x 2 1/2"
Blade length: 9 1/4"
CPM S30V
RC 58
Cyrogenically Treated
OD Green Micarta “Chili” Handle
Comes with a superb Cordura tactical sheath w/insert
Specs:
CPM S30V
RC 58
