Eric Bosworth
- Dec 30, 2008
FS
1 pair of
Moab 2 8” tactical size 12 wide Sage Suede and textile upper
Merrell M Select DRY impermeable membrane seals out water and lets moisture escape
Waterproof PU coated leather and ripstop textile upper
Rubberized mesh ankle upper for support and enhanced durability
Bellows tongue keeps out debris
Description
The same out-of-the box comfort you love from our original Moab hiking boot, re-invented for long days on duty. With a durable waterproof leather and ripstop upper and side-zip for easy entry and exit, the Moab 2 8" Tactical boot is built for the toughest environments.
See less
Heavy-duty YKK medial zipper for easy on and off
Non-Metallic lacing hardware
Breathable mesh lining
COMFORTBASE™ contoured design footbed with breathable foam cradles your foot in all day comfort
COMFORTBASE™ rubberized EVA midsole for increased shock absorption and cushion
EH rated ASTM F2413-11
Composite safety toe for lightweight non-metallic protection; rated ASTM F2413-11 I/75 C/75
Merrell air cushion in the heel absorbs shock and adds stability
Molded nylon arch shank for midfoot support and flexibility
Merrell M Select™ GRIP rubber tunes each outsole with durable traction that grips when and where you need it
Heat resistant outsole protection for brief periods of contact that meet or exceed 500 °F
Weight: 3lb 6oz / 1536g
New in box, never worn $95
1 pair
Moab 2 Tactical defense Waterproof size 12 wide Sage
The Merrell Moab 2 8" Defense
Composite Toe Boot has a suede and textile upper, and features Merrell's COMFORTBASE footbed and midsole technology for shock-absorption and cushion, an inside zip closure for easy on/off, and an M Select Grip rubber outsole is built for traction where and when you need it.
Features:
COMFORTBASE rubberized EVA midsole for increased shock absorption and cushion
COMFORTBASE contoured design footbed with breathable foam cradles your foot in all day comfort
Merrell M Select GRIP rubber tunes each outsole with durable traction that grips when and where you need it
New never worn new box $95
Ppff or Zelle
1 pair of
Description
See less
1 pair
Features:
Ppff or Zelle
