- Apr 3, 2011
Josh,
You want the deep cut I think it's 5" and it will handle most of your needs. Yes the 200-360 is about all you would ever need in fact I wish it ran a little lower like 170-180 less heat build up and blade teeth last longer at the slower speeds. One thing that is important is to "Set" the teeth on the initial cut(check Lennox blades web page they have some more info on doing this)...what that means is start SLOW don't force the steel allow the saw to do the work don't push more than necessary to allow the teeth to warm up and do it at the slowest speed. Once the teeth are set you can adjust the speed according to the material you are cutting. Annealed carbon cuts easy stainless if you force it will kill the teeth in short order!!!
This is where I get my Milwaukee tools...they occasionally have killer deals on reconditioned tools since they are a factory service center. Every tool that I have picked up reconditioned looked NEW I saw no wear or if it had even been used!!
https://www.cpomilwaukee.com/milwau...and-saw-with-case/miln6232-21,default,pd.html
Ordered! Thanks for the recommendation and link... I couldn't find another one that had the same features w/ the outstanding warranty of 5 years (I got it new for the warranty).
