Bigfattyt
- Jun 23, 2007
Have any of you makers used micarta for a sheath material. I am thinking about it for some smaller knives. Has any one tried it. I was thinking about using it in much the same manner as I see wood sheaths used. Maybe doing like a clam shell style sheath for a very short fixed blade? I would have to figure out how to do a retention device, etc. carve out the blade profile in two halves. Get a pretty exact fit, maybe glue in some type of thin soft liner? Epoxie the two halves together. Let it set. Drill some attachment holes? maybe even add a tech lock or pocket clip. round out the profile with sand paper? What do you think? could use matching scale material for the handles and the sheath.
My reasoning for this line of thoughts is
A. The strength of Micarta or G10 seems to be far greater than kydex/concealX. more heat resistant. Some of the pieces I have I believe are in the 65,000 psi for shear/ lateral strength.
B. I actually have some I could try without buying any.
What do you think?
Any examples? Pros, Cons?
Thanks.
What do you think?
Thanks.
