Well first off making MyCarta like Stacy says is an exercise in cost analysis to a degree--assuming that you want to make it, Epoxy is the wrong material to make it with. You can use different resins but epoxy is just wrong for that use. You can get bondo Resin at any Home Depot and most car parts stores, and apart from having a darkening effect on your base material is makes a really good MyCarta product. I will state for the record that I agree with Stacy, if the type and color of Micarta is available from a dealer that you want, then I would buy it from a dealer. I make a fair bit of MyCarta myself, and one of the ley items I made, which I would recommend to anyone going to make MyCarta, is to build a UHMW mold/press--I purchased some 1/2x 4 inch material from McMaster Carr, and made a rectangular mold/press, I screwed it together with sheetrock screws, and fitted a top that I can clamp down with bolts to get even pressure across the surface of the materials and end up with a nice even/square piece of material at the outcome.
Good Luck !!--Don
