Cougar Allen
Buccaneer (ret.)
- Oct 9, 1998
Okay, maybe soaking handle materials in gasoline and trying to set them on fire is a little ridiculous (to say nothing of shooting them) -- but it's fun! More seriously, there are a lot of other materials used for handles besides G-10 and Micarta, and there are serious questions in the minds of some of us about how much abuse some of them can take.
Shooting might actually be useful for comparison purposes. A while back I tested Miracle Weld, a kevlar-filled epoxy putty, by hammering on it. I degreased a piece of galvanized steel I had lying around, stuck a lump of the putty on it, waited a day to make sure it had fully hardened, and then started hammering on it. I worked up to full force blows with an 18 ounce (.5kg) carpenter's hammer and was unable to break the bond or shatter the stuff, only marring the surface a little.
I think that was a pretty good test -- since I obviously didn't mind if I destroyed the test lump you can believe I hammered it as hard as I could. There's still an unknown there, though; how hard is hammering as hard as I can? (Not likely the same as hammering as hard as you can.) There would be more of a problem if the bond had failed while I was working up to full force. Then it would be difficult to explain how hard I was hammering it when it broke.
It could be useful information if somebody wants to buy one slab each of a number of different handle materials, shoot them, and post pictures of the damage. That would be a consistent test. We would still have the question of how much a material can be damaged by a bullet and still hold up in normal use, but at least we would be able to compare materials and say this stuff takes impact better than that stuff.
-Cougar Allen :{)
This post is not merely the author's opinions; it is the trrrrrruth. This post is intended to cause dissension and unrest and upset people, and ultimately drive them mad. Please do not misinterpret my intentions in posting this.
-Cougar Allen :{)
