Thanks everyone!
foxbat34 I 1st used paper from Royal Brites called 'posterboard' which is the fluorescent green & black but I found when I ground down a cutoff that this paper has a white or grayish core, it still looks pretty cool but not what I wanted...The 2nd paper that I now use is from The Paper Company and comes in a 12" x 12" sheet and is solid through...I only use West Systems a marine grade resin and hardener, expensive stuff but I believe it is the best out there.
fod paper works great, no problems so far but I still need to do a destruction test on 1 of each type of paper I have used...whats the not of best of luck you have had?
MonkeyFist this was one of the few solid print 100% cotton fabrics I found, its solid meaning both front and back sides are the same, a printed linen is whitish on the backside with color bleed coming through from the front, being new at this I did not want the whitish color in the micarta as I found out with that 1st the paper I made
BlackToe Knives yep yep, you are dead on...now looks like I'll be driving 77mi rnd trip to go buy this material I found..another micarta junkie is made
