- Aug 20, 2015
Sorry, the reference prices would be dollars.
It is my understanding that quoting prices is not advised on this forum.
... I miss the idea of having the small pliers right in pocket ... I really did find use for the little pliers every day, sometimes a couple times a day.
After a tumultuous two months, I am now in Texas.
Getting the house in Maryland ready for sale, painting and doing small repairs, the micra was shoved aside a bit by the squirt. Taking plastic molly bolts out of walls, spackling holes, and taking stuff apart for packing the small pliers were like a third hand. They were big enough for small hex nuts, and the outside screw drivers were handy. On the road, the squirt was in pocket while herding a lumbering yellow Penkse rental truck down the road. On arriving in Texas, we just unloaded the truck in a storage unit and we're living with Karens sister in her place here in Georgetown while we house hunt.
Now, being stable for a while, the micra is back in pocket, but I find that I miss the idea of having the small pliers right in pocket. During the upheaval of the move, I really did find use for the little pliers every day, sometimes a couple times a day. Now, maybe not so much, but it was a little habit forming. I still like the tool set on the mcra for the better screw drivers, and slightly more compact size.
So, while immersed in the chaos of moving, the squirt seemed a better edc, but now in Texas, the micra as snuck back in the pocket. We feel slightly schizophrenic on the issue!
Zip ties are cake, even the bigger ones. Slide a small, sharp blade in and apply steady pressure. In time, POP! Cut 'em with my Case peanut all the time.
Thanks for posting a follow-up!
It's definitely interesting that even our most informed, well thought-out opinions frequently go out the window once actually tested in real life. Like when the screwdrivers on any small Leatherman turn out to be next to useless, or that pliers are handier than you might think. You adapt to the tools you carry, toohow do you remove zip ties, for instance?
???Not sure I understand this. There are size considerations, of course, but for close to 20 years, I have been using all three Micra screwdrivers quite often on varieties of screw heads. They work just fine, and the drivers are still in good condition. Although the only times I carry a Squirt is when I might need the pliers, if by chance I come across a screw that needs tightening/loosening, the drivers are usually up to it. What has been your experience?
22RF, I regularly cut wire, flashing and large zip ties with my Micra. Closer to shop shears.
Note: I buy mine bulk and used and in bad shape. I've learned to repeen the center pivot, carefully straighten the blades and to sharpen the blade (DMT credit card stones are ideal for this). I can usually return them to pis cutting wrapping paper and cutting dangling thread.
This gives me the recklessness to abuse my Micra with impunity. And that is when it starts to impress me.
If you're doing a lot that demands small pliers, the PS4 works just fine.
Could you please go into detail about how exactly you repeen the pivots, sharpen the blades, etc. A walk through of your Micra rehab?
I got a lot of 5, one cuts extremely well, two cut just ok and the other two hardly cut at all. I'm enjoying the one that cuts quite a bit. I've tried the Squirt PS4, I do like it but I just rarely need pliers and the scissors on it are pitiful. I use scissors tons though, so the Micra (or maybe a Squirt S4?) make more sense for me it seems.
Thanks in advance!
There is a difference in the cutting qualities of the Squirt and Micra. My wife has an S4 that she likes just fine, but the scissors are distinctly inferior to those on the Micra. I tried other S4s, and all were much the same. Of course, the sampling is small, so not conclusive, but my hunch is that Micras in general outcut Squirts.
Yes, thje scissors on a micra are far more sturdy for real world cutting of a wide variety of materials. The squirt scissors are more like the scissors on a Vic Classic, light duty for hangnails and threads, and an odd mustache or nose hair. The micra scissors are more for canvas, zip ties, rubber gaskets and such. Good general use scissors vs light duty trimming scissors.
Interesting thread and I am rethinking the small multis, with a key chain carry in mind. I really doubt that I would ever buy a small multi with its primary tool being scissors. I have zero use for scissors. But what the hey, views change.
The small keychain size mulitools have proven their worth to me, and I was a die hard non believer, until Dave (pinnah) introduced me to the micra. If an anti Leatherman person like me can be convinced, they must have something going for them.
