- Apr 15, 2012
The only media I can produce functional sharp burred edges off of is ceramics. I know I am not mistaking them, and the edges cut well, pass a crossgrain newsprint test and in some cases whittle hair. I suspect the difference is off of other media it is a true grinding artifact and off the ceramics its got a healthy dose of burnishing added in which can slightly draw out the edge as it work hardens it.
A good test is to give the edge a moderate smack directly into a hardwood dowel or similar. The edge will throw back light where its been hit as this burrs folds up. I normally need a loupe to see them, so if you're able to see with the naked eye you probably are seeing a burr. A microbevel will show light back at a more obtuse angle, the burr shows at a more acute - edge down, you will have to tilt the blade more to see the microbevel, the burr presents as a halo just off the apex.
I don't get this off of other media, tho did used to get a similar issue when backhoning on waterstones. If too much force was used the edge will curl slightly and look almost like a burr, almost like a wire, almost like a clean edge depending on how far it curled.
Interrogate them thoroughly, but always trust your eyes.
HeavyHanded,
Most excellent comments!
The work hardening effect and burnishing are the two things I was thinking about related to ceramics (plastic deformation & re-deposition effects). As blade steel has evolved (harder base metals and carbides) the cutting vs. burnishing efficiency of our media of choice has to be reconsidered.
I also really liked your comments related to how the light reflects (based on convexity or concavity of the surface). Being cognisant of where the light is coming from and at what angle the reflection determines the shape of the reflecting face and how what we see can/should be interpreted.
Good stuff !
