Micron, Monkey, Memes, and Mods
Tell me more about the charpy being used on welding rod!
I shouldn't say Larrin recommended the charpy test, but when I proposed that as my plan he agreed that we would get a good idea if the heat treat went well or not, assuming we had good data to get reasonable limits from
It's used as a standard way to test how much of am inpact a weld via a given rod can take prior to just snapping in two, you can actually see large enough enough differences between a premium and budget rod of the same spec, eg ER7018, that the difference will show up in an unscientific hammer test.
I find it pretty useful, because a weld seldom ever will break because it was bent and stretched into a full 90 degree or greater bend, but more typically because you ran into a tree with your tractor. Frankly the degree to which a mild steel joint can be bent or outright hammered over is kinda insane by knife standards, most knives won't hammer into a crack free 90 degree bend, ER7018 absolutely will.
MicronKnives MicronKnives
Jack what size and length are the sheath belt attachment screws?
youre gonna laugh....so i havent been checking them and I get off the zero turn to cut down some dog fennels after doing about 3 or so acre worth of mowing...and I got the belt attachment on my belt still and the nuts and washers..but no sheath, knife, or screws.....so I start walking what I cut and course cant find my orange handle knife I bought to not lose.....yeah I know irony and all......
I give up go back to the zero turn and there is the knife and sheath sitting under the seat. no screws though.....so I got to replace those. i already checked bunch of tek-loks I got sitting around and screws are too short to fit even with different rubber washers....so I figure ill just ask here instead of guessing......
so make sure ya tighten your screws folks and maybe blue locktite them. also zero turn over bumpy uneven terrain might make them come out......
thanks.
thanks.
Oh man!! Are you saying both the belt loop to sheath bolts and the scale hardware came apart?
We blue lock tite and torque the scale hardware, so that is surprising. Shoot me a DM and I'll get you sorted out
