Man, I just got the coolest gift from a friend, Ray Smith, in Utah.
This is a Mike Irie prototype (#3/5) modified spearpoint.
Dimensions
- 6.75" OAL
- 3" BL
- 3.5" Handle Length from pommel to index tip
- 1/8" thick ATS34 stock
- 15/16" deep blade
- 3/8" thick handle
- 1" deep handle at the widest.
- micarta slabs on full tang.
The knife is small and light enough for a neck carry, but the original kydex sheath is not slim enough in design. No big deal since I generally don't do neck carries except for fishing (in which case I use a Running Dog). So, my friend got Scott Hendrix to do a IWB sheath. This sheath is REALLY well designed. The knife is held in by pressure created with a concave top piece that hugs the blade rather than than molding around features of the knife. The result is a secure retention with a smooth quiet draw or resheathing with no plastic snapping sounds. This also allows the blade edge to be oriented out or in on the draw, depending on the user's preference. Works very well for the "drawpoint" approach. The sheath sports a heavy duty nylon retaining strap with a snap. Nice... no on and off by unlooping the belt stuff.
http://albums.photopoint.com/j/ViewPhoto?u=135433&a=7299341&p=25614730
http://albums.photopoint.com/j/ViewPhoto?u=135433&a=7299341&p=25614722
http://albums.photopoint.com/j/ViewPhoto?u=135433&a=7299341&p=25614678
The handle itself is very comfortable and secure with the combination of the index cutout and a pronounced ramp with minute filing. The holes drilled in the handle are well thought out. The middle hole is slightly larger than rest and provides a good index for grip changes.
The blade sports a very fine bead blast, or appears that way because of the gray sheen. However, it feels satin to the touch. There is a good belly to the blade which will allow for tasks such as skinning. The top swedge is sharpened right at the belly to the tip, giving this knife the attribute of a dagger.
I understand Mike Irie is no longer making knives. Too bad. This is a nice piece of work, crossing back and forth from hunter to tactical fixed blade.
Great knife, great gift, great friend.
sing
AKTI #A000356
[This message has been edited by sing (edited 08-05-2000).]
Dimensions
- 6.75" OAL
- 3" BL
- 15/16" deep blade
- 3/8" thick handle
sing
AKTI #A000356
