Cobalt
Platinum Member
- Dec 23, 1998
If the edge angle is equal, then the convex bevel will go visually higher on the blade stock than the "V" edge of equal angle. If the visual bevel width is held constant (which would be silly because it's just a cosmetic effect of imposing certain angles or arcs onto a given piece of stock) then the convex would be thicker but also have a thicker edge angle as a result.
If you were to impose a 15° per side bevel onto a 1/4" thick piece of stock it will look wider than that same 15° per side bevel on 1/8" stock. Fun fact: a BK-16 and BK-2 both have the same primary grind angle (unless they've changed something since the last time I measured it.) The BK-16 is a full flat grind merely because it is narrower than the BK-2, which is a saber grind only because it is so broad. And if the BK-16's blade were widened to equal that of the BK-2, that grind would stop much lower on the blade because the stock is thinner. However, at least up to that depth on both knives the cutting performance is equal. Yet most folks will tell you that the BK-16 is a thinner grind because of its stock thickness being lower and it being a full flat grind instead of a saber grind, which people automatically think is thicker. This is similar to the problems revolving around popular concepts of convex edges, or why people think scandi grinds are such good slicers when they're actually the thickest geometry you can have for a given stock thickness and edge angle (it's just thin stock and a really low edge angle.)
I will have to digest what u wrote when I am on my computer and not on this cell phone.
