milesofalaska
- Dec 4, 2010
Custom blades 1084 steel taken to about a 600 grit. Edge torch hardened, triple tempered. Back left softer. Razor edge put on and individually tested.
1084 high carbon steel. Over all 7 inches long with 4 inch cutting edge. 1 ½ inches wide and 1/8th thick. This is a whale shape. End is his tail, etched whale eye, nose, mouth. A little copper hammered in when forged for decoration. A KB Swhale 711 is the order code if inquiring $55
The test I put each blade thorough is .. to be able to cut a brass 3/8ths rod. I sharpen the rod to a point using the length of the knife. A second test I put the edge on the rod and beat the back with a hammer till the rod is cut in two. The blade can not snap, the back cannot dent, and the edge can not chip. Then must be able to cut a piece of paper in half without tearing. Past experience tells me if this test can be passed the blade will skin out a moose without re sharpening.
1084 high carbon steel. 5 ¼ inches long x 1 ¼ wqide and 1/ 16th thick. Acid etched scenes on both sides, one side a river the other side a flower. Taken to a 600 grit semi polish.A KB 1084 river 711 is the order code if inquiring $50
Best way to buy these is to go to my web site and use the pay pal shop cart. These two blades are at the bottom of the page. Or can email me send a check let me know. Any questions contact me. Shipping usually $5 for flat rate anywhere in the US priority mail in 3-4 days.
http://www.milesofalaska.net/Custom_knives/blank_blades.html
