Mili Cruwear Bundle
Feedback: +217 / =0 / -0
Looking to trade one of these bundles.
Any bundle will include the Mili
Not interested in trading the Mili by itself
Mili-I've carried it twice, Previous owner the same. Has a couple of very light surface scratches, shiny spot on the clip. Original edge, early lockup, centered and no play. Comes with box, baggie and paperwork.
http://imgur.com/a/Rgu1XpO
Bundle 1: https://imgur.com/a/q7BKkO0
Crawford Hawkbill Intregral -3.5" bead blasted blade. Handles are made from one piece of 1/4" thick 440C. I have carried it twice, has some minor snail trails. Snaps open with authority, very sharp.
Has the original edge
Matthew Cody Hawkbill- 3 1/4" acid washed 3v blade,OAL is 7 3/4", liners are ti and the scales are coyote brown G10. Has been carried and used lightly, edge is original. No blade play, flicks open easily and is centered. Pocket clip is ti also
Bundle 2: https://imgur.com/a/68eifUa
Schwartz Ti hawk- 18"OAL, Edge is roughly 3 1/2", stock is slightly over a quarter inch. Has a hammered/post apocalyptic look. Has matching zombie green/black paracord wrap. Spike isn't sharpened, but it is very pointy. Comes with a zombie green blade cover. Has not been used, carried or sharpened. In the condition received.
Second blade is is a ti/cf blade. Blade is 5", combo edge with one carbidized edge. CF has been secured to the TI core using sheer strength epoxy. Matching green paracord handle. Blade thickness is approx. 3/16th". Comes with a green sheath. Has not been carried, used or sharpened.
Bundle3:
https://imgur.com/a/Wlzua72
GG&G Hawk- Black s7 coated blade 3/8" thick. Only has one spot where the finish is peeling. Black g10 scales. Has not been used, carried or sharpened. Comes with sheath
Custom Hawk- roughly 5/16" ultrafort head. OAL is 14" or so. Satin flats, semi mirror bevels. Roughly 7 1/2" oal for the head, the edge is just under 3". Handle is a single piece of red anodized aluminum. Fills my medium hands well. Has replaceable rubber rings to assist in grip. Hardware is Ti. It's a breaching/rescue axe so the edge isn't sharpened. No sheath. Has not ben used, carried or sharpened
Bundle 4:
http://imgur.com/a/jh5aM5M
https://imgur.com/a/u7Ydlu1
Bear Ops- Just under a 6" bead blasted 154cm blade. Oal is 10 3/8". Cocobola scales. Has been sharpened and stropped. Has not been carried. Comes with sheath and box
Bear Ops- Chisel ground tanto 154cm black coated blade. Black G10 scales. Has been sharpened and stropped. Has not been carried. Comes with sheath and belt attachment. Also comes with box and paperwork
Siegle- Kind of a hybrid cleaver/small hatchet. 5160 steel, 1/4" thick. 11" oal, blade is 6 1/4" with and edge just over 5". Scales are a brighter green G10. Comes with a kydex sheath, no Tek lok. Has not been used, carried or sharpened. Has some scratches from sheath insertion
Smith and Wesson 960- First production run 6 1/2" clip point CE satin blade, 3/16" stock. Has insertion marks from sheath. Has not been carried, used or sharpened. Comes with correct leather sheath
Bundle 5:
https://imgur.com/a/w1CXkvl
http://imgur.com/a/CvIr36X
https://imgur.com/a/tljDb13
White Wolves/Woodard Combat Auto- 4" Blade. Aluminum handles. Overbuilt and 4mm thick blade stock. Has not been carried or used. Comes with a belt sheath. Fires hard and no blade play
Leek 1660cb- All three are unused, uncarried and unsharpened. I am the 2nd owner I believe. Solid lockup, no play. All look to be fairly centered, maybe favoring non lock side by a hair. Comes with box, baggie, paperwork and silica packet
Hoover- 3 3/4" acid washed 3v blade. Handles are ti and ti/cf. OAL is 9 3/4". Bought this from Hoover directly. It has been lightly carried, sharpened. It's a little rough, the blade has rub marks on show side due to rubbing the liner. Has a little up movement, no side to side. It's a beast of a blade and functions well on PB washers
Open to folders and fixed, gear, lights, gadgets etc. My want list is fairly wide, throw out an offer, worst ill say is no. Multiples are ok, used/users are ok. Partial trades plus cash works too, I don't have any cash to add to a deal.
Established members preferred, will work with low feedback, but you'll probably have to ship 1st.
Imgur is giving me issues today, only let me post 3 of the pics, and the quality is degraded. Will more more photos of the Mili if needed.
