I’m not sure about the other Warcrafts, especially the newer 4034 or 3v steel versions but this San Mai version (the medium size) is indeed hollow ground. Weird though because in the description from Cold Steel, they say it’s a flat ground secondary bevel. Anyway, it’s a beast and excellent slicer at the same timeWhat on earth is this and when the funk and wagnalls did they introduce a hollow ground Warcraft!
And they're clearly bungling the 'chisel ground' bit, right? I am thinking that it's a case of some unfamiliar staffer recycling bits of old advertising or mixing up what different terms mean, because that's clearly their normal hollow/compound tanto grindI’m not sure about the other Warcrafts, especially the newer 4034 or 3v steel versions but this San Mai version (the medium size) is indeed hollow ground. Weird though because in the description from Cold Steel, they say it’s a flat ground secondary bevel. Anyway, it’s a beast and excellent slicer at the same time
Even then, not so sure I’d be pounding around and opening crates with knives that are worth several hundred dollars and are so hard to even find lolSorry, Ididn't catch the $80 budget limit.
If it were me, I wouldn't either. But it was for our only son who was about to go into harm's way . . . .Even then, not so sure I’d be pounding around and opening crates with knives that are worth several hundred dollars and are so hard to even find lol
Not really. Unless it’s one of those grainier coatings.Don't most coatings detract somewhat from the slicy aspect unless it's a DLC?
While durable, the durability comes from the extremely thick and heavy blade stock, may be good for outdoor activity. They are designed by an outdoor man after all.Seems criminal nobody has mentioned the Beckers.....
BK10, 7, or 9 might be perfect for you, and only a tiny bit more in money, prob could find used ones here with your budget.
For thing like military per OP request however, they are close to dead weight. You don't need 5-6mm thick knife to do most of the activities.
Fantastic knife with one of the most comfortable handles I have ever seen. Really great knife!
Future models will be thinner, and most will be in 3V.Old Becker knife production were 1/4 inches (a little more than 6mm), I saw a few of them at my local store.
Your knife look pretty nice! Though, that blade stock looks kind of thick. If it is for military, I would go with hidden tang.
