Military Help
Hey guys,
Just got a Military PE non coated. The action is decently stiff. To stiff for my taste. I lubricated the action. I tried to loosen the pivot slightly to no avail. I dismanted it and polished both the pivot area of the blade and all the 'rubbing' area's to about 5 micron or a high polish. I ensured to remove very little steel. Should the copper washers be fixed to the G-10 Scales? Should I try to loosen the Torx heads that fix the frame a slight bit? The thing locks up like a vault which is awesome but can anyone give me any help?
Thanks
My D2 version was a little rough when new, but it smoothed out in time. Not what I had come to expect (based upon previous versions I own), as they are usually pretty smooth.
I tried adjusting the pivot bolt and Militec, but not much as I prefer a secure lock over smoothness of opening and it only helped minimally.
I LOVE the stiff action. I would not call it "rough," but I really really really like the military's action. instead of making the Mil into what you're used to, I recommend getting used to the Mil... it's the best folder ever!
I have a plain s30v/g10 Mil and it's very stiff. I don't mind it because it feels secure but I'm confused when I read about people being able to flick a Military open. It's damn near impossible in my opinion because the closed retention is unbelievable. It's smooth when you're past the detent though.
I have a D2, two BG-42 and an S90V Millie, none of which are stiff. As with all knives, they will loosen up a bit through use.
However, if you find it difficult to open, I think that an email to Spyderco may be in order.
I had an s90v cf millie for a while and it was stiff when opening when brand new.
After a while it smoothed out quite a bit on its own.
I have the same problem with both of mine. One was my EDC for three years. The other is brand new in box. They are too rough/hard to open. I've done everything I know to do to ease the opening. Nothing works.
Have you tried the Tenacious? It opens perfectly.
My CF/S90V is flickable. The action is stiff... the stiffest I've had on a folder... I LOVE IT. ...but with a "snappy" thumb movement, it flicks great... just takes practice! I can't think of any reason to have it slippery-smooth. This knife is made for ACTIVE people...kinda like someone in the "Military." In a situation of rigorous activity, closed retention is as or more important than any other function of the knife. Next in lline of importance is "training," if you will,...as in: Practice using your knife. Any new tool takes a little getting used to.
A good closed retention is more important than a buttery, smooth as glass, opening IMO. In this respect, with sooooo many inadequate folders out there...(take your pick), I reckon we should praise the Military for what it is!...a hype and gimmick-free, perfect tool. I LOVE the closed retention...
I believe that the complaints herein are on the topic of the knife's intended design, and there are a LOT of others which fit your criteria... The Benchmade Dejavoo or a 710 seem to be a lesser active, large knifeknut's best friend! Check those out! :D
I think you are exactly right. For the last couple of months, I have been leaving my Military at home and carrying a BM 710 every day.
Thanks for the suggestions here guys. I'll wait to see if it smooths out a tad with use. I'll try a little lapping compound on the rubbing area's and just use the crap out of it.
+1 to that
...and that too
my Dejavoo is absolutely flippable and fun to play with, but i'd rather have my stiff action Millie on me WSHTF
Hey guys,
Thanks
Take off the clip..and see if that smoothes everything out... Step 1
