I don't think it was Hemcon, but rather Woundstat. Woundstat was recently pulled from all SOCOM supplies because of its overzealous clotting capacity causing complete blood flow stoppage to entire extremities and had also produced clots that traveled in the bloodstream.....which is bad.
But in general, the article is poorly researched. The US military did in fact introduce hemostatic agents quickly. The real problem was two-fold...1. Lack of PROPER training for the end user, and 2. The original powder form was not really conducive to extreme field use, and did I mention lack of training!?
The $89 bandage they are talking about....Hemcon is not a replacement for gauze therefore either the writer has no idea what he/she is talking about, or once again we get back to the training issue....Hemcon is to be used, in a major bleed situation, either arterial or heavy venous in which a tourniquet or other direct pressure methods, or other hemostatic agents are not appropriate...i.e. like the neck.....once again..from the field trauma perspective (I'm only speaking from that angle, not the CASH level medicine talked about) the article is way off.
So, on a side note, I've seen several non-combat trauma FAK's around the web which people put in hemostatic agents as their only stop gap. Bad idea....if you are not trained, you will try to apply this stuff and watch someone bleed out right in front of you.
H
