Military vs. ZT 0560 ...
Yesterday I got my new ZT 0560 and I wanted to share my thoughs on it vs. my EDC, the Military CF M390.
As you can see, they are both rather "large" knives - that grid is 1/2" per square, by the way, and sorry it is a little dirty, that is my machining workbench:
When closed the Milie is a tad larger overall:
When opened the different is a little bit more noticeable, length-wise, as the Milie has a longer blade:
Not only the ZT is significantly heavier, but it is also thicker pretty much everywhere:
The blade shape/grind tells you all you need to know as to the intent/usage for each knife - the Milie "is" the slicer out of the two - can't argue with the physics here:
The ergonomics on the ZT are fairly good, but this particular area bothers me a little bit. Note how the G10 scale is not cut all of the way to match the liner here - it makes operating the frame lock much harder than it needs to be. Here the Milie shows a huge opening which makes unlocking easier, even with gloves - as a LEFTY, this makes the ZT harder to use compared to the right-hand version of the Milie:
The jimping is very nice in the ZT. The edges are a tiny bit sharp, so I would gently file those down before using it, but along with the 3D shape of the scales, the ZT has outstanding "gripiness" (I know, a made-up word) in the hand - feels very secure in the hand:
So my take:
- Opening: flipper vs. big hole in the blade: Once you put your hand/finger aligned with the flipper "lever", the ZT opens "like magic" - very fast. But the big hole in the Milie is fast as well. Picking one method over the other is more of a personal preference, but not enough for me to pick one over the other. To me it is like a draw - they both open fast enough for me, but in terms of "coolness" the ZT has the "wow" factor (which might be intimidating to non-knife people).
- The Milie is designed to cut first. It is clearly "the" slicer out of the two. The Milie is also significantly lighter in the pocket, and slightly thinner - easier to EDC in plain clothes. But compared to the ZT, it does not look it could/would take as much abuse or "hard use" as the ZT.
- The ZT would be my choice as a firefighter, or any other line of work/usage where the knife might see some abuse - it seems/feels like a tank, and it does weight more as a result of its construction. But it is not as specialized in cutting as the Milie due to is thicker blade/grind - that is an important sacrifice the ZT makes in order to be a "stronger" knife. I would be more "afraid" of damaging/breaking the Milie under hard use - not so with the ZT. In your hand, the ZT oozes confidence - it feels like you can't hurt it (not easily at least). The gripiness of the ZT is definitely better to me than the Milie with the CF scales. I am not saying that the Milie is slippery, but that those 3D textured scales on the ZT "do" work extremely well.
- Ideally, I would love to EDC both - I would then be prepared for anything from normal cutting chores (Milie) to hard use/battling Zombies (ZT).
Which one I plan to carry as EDC most often (and not because this is a Spyderco sub-forum): the Milie. Why? Because for "my" typical needs/uses, I need more of a cutter/slicer than an "indestructible" knife. If I knew before hand that I might need a stronger/heavier duty folder, I would leave home the Milie and take the ZT.
Will
Personally, I'd take the Millie, but there is nothing wrong with the 0560. Thanks for the pics!
Great review (and pics) of two great knives. :thumbup: :thumbup:
My 0560 slightly takes an edge(no pun intended) over my G10 Military for EDC, but I do use the Millie when I'm at home for food prep.....that full flat grind easily outslices anything else that I have in my kitchen. :D
2 really good knives for sure. I'd carry the Millie as an EDC but love the ZT in the field.
Well done, sir. Enjoyed the pics and the review. And yes, the G10 on the ZT is not cut to match the scale, as you mentioned. That's too bad, as it would be very easy to do. Is it "reasonable" to just fix that with a Dremel. Would the repair show or be the same color? Obviously, don't watch to damage resale, but I'd rather have a knife that "works" than one that doesn't quite.
I love both the Military and ParaMilitary models. And your M390 will last forever, IMO.
Fortunately, the 4" blade is legal here in Florida for EDC.
I have read other posts where the ZT owner leaves his at home in favor of a smaller knife, as all that "strength" may not be often necessarily. But, sometimes, it is. Both Spydie models are 0.450" wide, which (as you said) makes them very nice for carry.
Sonny
Very nice comparison. For me, I have bigger/heavier folders but prefer the ligher/slimmer Military. I've not run across a situation where the Milli was not enough knife.
You shouldnt have to use a Dremel to fix the G10 so it lines up right on the ZT, it should come correctly from the factory, especially for the price of them. I think it is a flaw or poor quality control.
I do like the looks of the 0560 but I dont think I would buy one, knowing the price and that it doesnt line up correctly. It looks like it was made too big!
I have absolutely no problems closing my 0560. Different strokes for different folks. The 0560 needs no changes IMO, it's the perfect ZT.
I'll agree with OP that the Millie does cut better, but that also lends itself to breaking the tip easier in harder cutting tasks. My EDC rotation right now is the 0560, s90v pm2, 440v Millie, Strider SnG, CRK Zaan, 0302, and an Endura Spydie-edge. I switch off either every day or every few days to spice things up a bit.
That isn't a quality control issue, it is how the knife was made. The scale lines up perfectly with the other side of the knife, the liner just has more cut away in that area. I don't know the reason for it, but it is how it was designed and I'm sure there is some reasoning behind it.
That liner cutaway is to allow easy access to the framelock on the other side and for aesthetics, its not poor design.
I had a dilemma choosing between the Lionspy and 0560, ended up getting the m390 Military off the forums instead.
From using mine, my assumption is that so you have more room to get your thumb in there and disengage the lockbar.
Well, like people said, to each its own but to me it is a flaw. I didnt say it was a poor design but it should have been cut back more, maybe not all the way to expose the liner but at least half way back because it doesnt need to stick out like it does.
Very nice review. These are currently two of my three favorite EDCs (The other is an AFCK in M390).
The Military is definitely the better cutter. I don't consider it delicate at all. High-performance cutting requires a thinner profile. Still, I really like the 560. It's more complicated and busy and less refined and less elegant, but it works. It has a nice feel. I didn't have serious problem unlocking the blade in stock condition -- as I did with the Gayle Bradley -- but the overhanging G10 scale gave me the excuse I needed to trim it back to the liner. Yep, resale value gone. And while I was destroying the resale value, I also ground down some of the sharp jimping. Both of these knives are so well designed ergonomically that the jimping is just decoration. After the sanding, the knife is much easier to close.
If I had to choose just one, I'd go with the Military because of its cutting profile and because I like M390 a bit better. But I like and carry both (not at the same time).
Here's a photo of the cut-down liner.
Quality control issue? That's laughable.
The scales are designed that way for a reason, the reason being accidental lock disengagement. Knives with huge cut outs on the non locking side have historically been the subject of contention due to the fact that a LOT of people think that big cutouts = accidental disengagement under use. That is the reason behind it, whether or not is an issue is up to you.
I wouldn't call it a design flaw on 560, but I disagree that accidentally disengaging framelocks is an issue. There are lots of knives with large relief areas that permit easy, intentional disengagement of the lock. Those knives have a long and solid safety record.
Even with my scale dremmeled back to the liner, there is less relief than on a stock Military framelock or my Sebbie.
None of us know why the scales were left hanging long over the lock. Maybe there was a good reason, maybe not. But safety is not an issue.
Hmmm, you know what? The floating G-10 allows those of us who don't want the cutout to be satisfied with the knife -and it allows others to easily modify a cut-out. I personally don't like cutouts that large (which was the main reason I got rid of my mili). It is a win-win guys.:D:thumbup:
Um, YES, yes we do (referring to bolded text in quote).
A quick search over in the Kershaw subforum would yield the correct answer (and no, I'm not going to search it for you). As CTS mentions, the G10 cut-out is DESIGNED to be that way by the manufacturer. It is an intended feature. :rolleyes:
