Militec or Tuff Glide
Yoda,
How much of the militec oil did you remove after application?
BTW, I used to use mobil 1 synthetic on my SKSand AK rifles. Works great.
Soon after, I started using copper based anti-sieze grease... another great lube.
Saw that Emerson Knives was trying some copper anti-sieze on their pivot washers at Blade Show West.
it's mostly an industrial use grease.. used in glock pistols and it makes sense since Gaston Glock is a major plastics and tool manufacturer before he got into firearms...
I use it because my job uses them to grease the threads in high temperature gas burners. It's overkill for knives since you're not dealing with extremely high temperatures, but the cool copper color is attractive.
i use militech on the blade(corrosion protection) and tuffglide on the pivot(lube) myself, though either one is really fine for either.
You're comparing two rather different lubricants. I use Militec-1 on my balisongs and push-button autos, but it's too thick to use on my OTF autos, which are rather touchy when it comes to lube. Reccomended for those is Rem-oil, but I find Tuf-Glide works very well. So I'd say that you should choose the right one for your particular application. Either should work well for most. Militec-1 is thicker, but smoother, which works great for balisongs and high-tolerance pivots like on Sebenzas. Tuf-Glide is much thinner, which might give more speed, but less of the sexy-smoothness Militec-1 gives..
At the very least, email Militec for the free sample. I got mine nearly a year ago, and despite the apparent small size of the bottle, and the number of knives I use it on, it's still got plenty left. A 4oz bottle (like the Sniper pack) should last a lifetime or 2. i bought a .5oz needle-tip bottle of Tuf-glide, plus an 8oz bottle for refils 4-5 months ago, and I'm only 1/4-1/3 the way through the .5oz one. A little goes a long way, so don't worry about the aparent high cost.
For protecting, I use a Tuf-Cloth, which is basically a cloth soaked in Tuf-Glide. I prefer this over Militec, mostly because it's easier to wipe clean in case I have to use the knife on food.
for sebenzas, nothing beats Militec. even better than the CRK grease, IMHO.
I applied it using a cotton q-tip, burnished it well into the surface, it left a light film that I didn't wipe off, as I didn't wipe off the film for any of the the lubes I tested. I applied it to both room temperature and "hot" metal as militec says is necessary, no difference in corrosion resistance.
On militec being too thick, for OTF's you should wipe off any visible oil, it's an extreme pressure lubricant that works best when there isn't much there. A light sheen to the surface is all that is necessary.
